This started right after i changed oil to 20W-50, i dunno why. It runs flawlessly above 2000rpm, but below that it misfires occasionally and almost dies if you don"t help it with a throttle on lights example.
I took carbs apart yesterday, and there was nothing expect a big waterdrop on the right carburetor bowl. Rubber plug covered slow jet is weird because you can not remove it. Pilot screws were out over two and half turns, so i corrected those (CB250N). Two days ago i got in bit of trouble with it because it stopped running under 2000rmp at all with both cylinders, just tried to stall. Hard to ride like that. Now after the carb clean-up it runs again, but not well. There"s misfifre like in every three seconds, and revs try to drop. Plugs looked pretty good, insulators were totally white, no deposits found at all.
Stator has been replaced recently by the owner before me, i don"t think it"s the stator, it charges well, starter motor sings high. CDI or the coil? Performance actually got clearly better afer the carb clean-up and adjustment. It accelerates better now. One weird phenomeon is that it accelerates best when you slowly unwind the throttle while the revs grow. I have had this phenomeon with some other bikes too in the past. Wait when it hits around 6000-7000rpm, and then start to unwind the throttle slowly so that you end up with around half throttle when it"s time to change up. You get extra kick out of it this way.
It needs new exhaust rocker arms and camshaft fix pretty soon, head gets bit noisy pretty soon after the valve adjustment always. Exhaust valves make bit of noise around 5000rpm. Noise almost goes way after the valve adjustment, but comes back pretty soon. Exhaust valve clearance grows from 0.15 to 0.25 in 300km again. I think exhaust rocker arms and cam are bit worn. Long time ago i had VF750F, which ate rockers arms for breakfast. This has all the same symptoms. CDI boxes are not expensive, but original rocker arms are.
