Anyone here ever convert their plain cam bearings into roller bearings? Got details/general costs on this process?
Mega Cycle does it for $360. I am sure if you can find a megacycle dealer you can get it done for less.
Thanks for the tip, Maasey! I downloaded megacycle's catalog and found it. that seems pretty reasonable, actually - at least compared to the others who offer this.
I just talked to megacycle 2 days ago about said bearings. The most expensive part of the deal was to modify the cam ends and put a hardened sleeve to ride on the needle bearings, My question to them was why, its a cast iron cam only turning 9300 rpm. Then I said even the big cam from 68 69 was a 10500. now this is on a cb350 mind you. But the engineer I talked to didnt realize they made 2 diffrent cam and rockers for the 350.. He said it would distort the cam. my question again was there is still oil flow to the needle bearings, and the only 2 purposes are less crank whip to the points and a free'd up upper rotating mass. More input from the experienced engine guys is excepted PLEASE. Im new to the engine building thing.
megacycle does this for the 350s...never checked about 450s but suppose they do.
