Hey all. Not sure if this is something that belongs in electrical, or engine since both are in play here.
My CB350 K4 is only running on the left cylinder. Right fails to fire and has not fired since i rebuilt the bike.
So far I've looked at:
Spark: i do have spark on the right. Did the thing where you see if it sparks outside case when kicked. I do get a spark. And I've checked the gap. The pug comes out clean, just soaked in gas. Both coils are new from common motor.
Timing: Have set timing based on the Common Motor video. I am running a Shockwave system. Which makes reading through old threads a little bit harder.
Compression: Solid compression. First thing i checked when buying the motor. Have also set the valves and adjusted cam chain based on the common motor video.
Fuel: Have checked the petcock. Good flow, no obstructions. My lines are transparent, so i can see that gas is getting into the carbs.
Carbs: Mikuni VM28. Both adjusted to mirror each other. The left runs like a champ, right refuses to fire like a non-champ.
Battery: Running an AGM battery. Charge is at about 75% and reading 12.4.
Im am kind of at a loss right now. You guys have helped a ton in the past. Was hoping someone would have an idea on what to check next. Hoping to be able to ride this spring.
Thanks in advance.
Thanks in advance.
