Hello! New register here. This site kicks @$$, very informative and helpful.
My 74 CB450 began losing spark intermittently in only the right cylinder causing it to cut out. After several brief hiccups, each longer than the last, the right cyl cut out completely. I checked the spark plugs, they are good. I believe it not to be fuel delivery because during the hiccups it would backfire upon coming back to life as if to expell the unburned fuel.
In your opinion, what is the most logical order in which to troubleshoot this issue and based on the description what may be the problem?
Thank you!
dpmbn8
Thank you!
dpmbn8
