Revs REALLY HIGH at startup without throttle application!!
Hello you beautiful souls.
So I recently got my cl350 running again not that it never was but changing cables and cleaning carbs, but I'm having a problem with it reving very high at start up and it never did that before. It goes up to 4000rpm and stays there. I thought it was the throttle getting stuck but i checked and snaps back nicely, but I did adjust the cables from the carb and it helped a tiny bit but not nearly enough as it should. The throttle cables are kind of long and I don't know if that could be a factor. I even have the idle mixture screw all the way in and choke off.
Ive been reading around and I've read that a vacuum leak could be a factor but I really have no idea. Any help would be appreciated.
Thanks
Thanks
