Hello everyone, I have a 1974 cl360 that I just recently got started. At first, the right cylinder wasn’t firing, then the left, but that fixed itself, then it would die if I gave it any throttle, and now it immediately revs up to 5000+. I’ve checked the idle screw, and air mixture screws, but no change with those. Any suggestions on what this could be or how to fix it?
...Many possibles....Can't rule out any without more info.....
Feel free to phone to discuss....540-525-5199
As ^^^ said, could be a lot of things. What immediately comes to mind is a vacuum leak. Check around the boots with carb cleaner while it's running to see what happens.
Make sure the pilot screws, to start out, are only a 1.25 turns out.
Make sure your throttle cables are not pulling the throttle open at all.
Vacuum leaks:
-Throttle shaft plugs, ensure they are not damaged or even missing. This will cause Idle to be very amiss.
-Make sure the intake manifolds (carb boots) are fully against the head, no gaps between them and the head AT ALL.
-Make sure the carbs get fully seated into the carb boots, sometimes the boots can sag and cause them not to seat fully. They can also sag and develop cracks.
1975 CL360
A vacuum leak at the carburetor boots is most likely. Another possibility is the vacuum-controlled pistons in the carbs could be stuck in the up position, exposing the main jets and pulling fuel to rev high at idle.
