StillStanding462 is the name I used at the 450 forum - won't go into why.
From: MSN Nickname73_CL450 (Original Message) Sent: 10/29/2008 1:48 AM
Okay so a few of you have mentioned the XS650 replacement coils from Mike's XS. I've just received mine in the mail today and I really would like to install them correctly... I'd hate to melt them because I hooked them up backwards.
I think a few of you have already installed these coils so any advice / instruction would be fantastic. I've got new wires and non resister plug caps (thanks to the group for that advice). My 1973 CL450 k5 runs pretty good on 1.5 cylinders... I can't wait to ride her when the right cylinder has consistent spark.
Thanks guys!
Chris
First Previous 2-9 of 9 Next Last
Reply
Recommend Message 2 of 9 in Discussion
From: MSN Nicknamestillstanding462 Sent: 10/29/2008 3:16 PM
Sure wish someone would answer this, as I am getting some in the mail tomorrow.
I'd especially like some details on the physical mounting - the electrical part is easy enough.
bill
Reply
Recommend Message 3 of 9 in Discussion
From: MSN Nicknamestillstanding462 Sent: 11/3/2008 5:41 PM
Here's a link to how I just did it...
http://home.comcast.net/~tbpmusic3/AftermarketCoils.pdf
bill
Reply
Recommend Message 4 of 9 in Discussion
Thanks! That's pretty much how I'm fabricating my mounting brackets except I'm using a wider piece of steel so the coils will be further apart. I would have had is finished this weekend but multiple Halloween parties got in the way.
Reply
Recommend Message 5 of 9 in Discussion
From: MSN Nicknamestillstanding462 Sent: 11/3/2008 6:29 PM
Be real careful about having the coils further apart - the tank won't fit on !!
I had to move mine in from the first position that I tried, because they hit the tank.
There's lots of vertical room, not much sideways.
bill
Reply
Recommend Message 6 of 9 in Discussion
COP - Coil-On-Plug coils are very cheap and plentiful.
From outboard motors to BOP Americans to aircraft.
Ebay to junkyards.........
Reply
Recommend Message 7 of 9 in Discussion
The problem with COP coils is that they are too low in resistance for stock points or common aftermarket ignitions.
Without a way to limit current there is no way to use them.
Reply
Recommend Message 8 of 9 in Discussion
RYBOWEN,
Current-limiting resistors. Wheyou have 1.9 ohm coils and that is too strapped, drop in series 3.0-3.2 ohm resistor, about 5 watts, looks like a grey block of concrete. Dino suggested to keep aftermarket coils to 5 ohms.
Paul T.
Reply
Recommend Message 9 of 9 in Discussion
From: MSN Nickname73_CL450 Sent: 11/10/2008 3:55 PM
Mounted and wired the coils. Bike fired right up. Plenty of consistent spark on both cylinders. Went for a quick ride then noticed a big oil leak out of the left rear cover. Looks like it's time for allen head bolts and fresh gaskets.
