Short version:
I'm wondering if anyone can tell me where to find replacements for the rubber hose/boots that connect the carbs to the airbox? Or a workaround/hack that works well. Mine are cracked beyond repair.
Long Version:
I have a 1978 hawk cb400tII that I picked up for $300 and have been fixing up. These forums have been a great resource! The bike is currently running with just a few hiccups. It seems to bog down on the lower side of the power band. I think this might be due to the rubber boots that connect the carb to the airbox. I've taped them up as good as I can for the time being but can't find replacements. This is the main place I can think of where the bike might be sucking air. I've cleand the carbs and done all the other maintenance things I can think of. It runs good once you get to higher rpms or if I ease the throttle up. But if I try to dump it on the low end it bogs down and cuts out.
The other possible reason for the loss of power is that the pre-exhaust chamber is rusted out on the bottom. I'm getting a new one off eBay Friday. It seems silly that I can't find anything to replace these boots but I've searched high and low (including these forums). I'm almost ready to get some rubber cement and hose to make my own.
Thanks!!!
THey only came with the air box, not separately. Check the builds in the sohc section for somebody near you that is turning theirs into a 'cafe' style bike. They usually prefer pods for that style (which are difficult to tune in ). Also check the ads in the parts for sale section. Failing that , there is a possible repair using cement and rubber from a scuba shop. (think wet suit)
eBay, search for the airbox and you should be able to find a good pair of boots, they can be refinished / softened up. That's is what I ended up doing
Thanks for the info. I feel like I'm going to end up making my own with hose and rubber cement. I don't want to have to buy a whole airbox just for the boots. If they were in really really good shape I might.
