1 - 14 of 14 Posts
I've heard people mention replaceing their CB/CL coils with modern replacements from Mikes XS.
1.) How do you determine your coils are getting weak?
2.) Which models from Mikes XS would be a suitable replacement on a '73 CL350?
Thank you.
Just replace them and don't worry about it anymore. Your coils are almost 40 years old, they were never designed to last that long.......
http://www.mikesxs.net/products-27.html#products
Part #17-6805 - Ignition Coil (Need two)
Part #23-3114 - Non-Resistor NGK Spark Plug Cap (Need two)
Part #23-2906 - XS Performance Silicone Plug Wires
I just picked up a '72 CB350, so would these items, you listed Bill, be the same for it as well?
Also, how comparable size-wise are these to the stock ones? Just wondering about fitment and mounting issues.
Thanks for listing them.
There's an article here about how I did it on my 450 mutant - http://www.hondatwins.net/forum/viewtopic.php?f=29&t=782
I had to do a minor modification, but others have reported it as a direct bolt-up.
It applies to all our points-based 180 degree Twins.
I suspect it would be a bolt-up (or close to it) on a 350 as well, they're virtually the same mounting setup as a 450........
Definitely a great deal, and will completely eliminate that problem for many years to come...
I just did this mod. Top notch service from mikesxs. All you need is some flat sheet metal. Really easy.
Do yourself a favor and get new points and condensor off ebay for 30 bucks.
HerrDeacon said:
I swapped the points out on my KZ for a Dyna electronic ignition. Is there anything available like this for these Honda twins?
Word is that a Gold Wing Dyna rig will work on our bikes.
Can't confirm that personally. However, the early Wings use the same points as a 450, so there's probably something to it.
There's also the HondaMan points "amplifier" system, which I'm putting on my 450 this winter - already have it in hand.
I've got two sets of PDF instructions on modifying and installing the GL1000 Dyna system on a CB/CL450.. One from a member here I do believe. Not sure where I got the other set. It's been done before by members here on a 450.
As for the CB/CL350 there are options out there for electronic ignitions as well. Most are pretty darned expensive though from what I remember..
Nuttin wrong with points when you master them.
If it will work on a 450, then it will work on a 350..........
1 - 14 of 14 Posts
