How can I get the crank to stop rotating so that I can remove the nut that holds on the gear for the primary chain?
Stick a penny or two into the primary gears between the crank and clutch... Should stop things from turning without harming things.
Slide some rope into a spark plug hole, leave the end out. Turn bike over, it will compress the rope and stop piston. That penny idea sounds good too
