I've taken out all of the screws, removed the stator cover and it seems that it is going to come off. Except in the upper left where the starter is. I don't want to pry on it and end up bending or snapping something. Is there something that I'm missing or should I just use more force?
Here's where I'm talking about.
Theres an alignment pin/dowel (sorry not sure of the correct name) that helps to align the side cover in the spot you have circled. I'm guessing this is hanging you up. Should pull straight off must may be a bit stuck.
