I have the rear balancer out and the bearing cover removed. The front balancer weight moves freely on the shaft and the shaft turns easily and slides back and forth about a millimeter. I think the slippers are removed, not 100% sure what they are but certainly the chain is just dangling, no tension, only hooked to the front balancer. I do have the shop manual and refer to it often. The only thing it says todo that I haven't done is removed the cam tensioner, but I don't see how to do that. I've looked at the exploded view in the manual, and it would seem that you'd have to have the camshaft and cam chain out of there to remove it. I also, don't see how it would affect the shaft. I do understand the dot, and the quadrant nut, the latter which is off the shaft at present, and how the tensioner for the balancer chain works. I appreciate everyone's attempt to help me, but I'm stymied. I thought maybe there was something going into that groove on the shaft that was holding it, the end of a head bolt or something. If push comes to shove, I'll attempt to replace the damaged rear balancer and shaft and just reassemble as it is. But it's a lot of work to do a half assed job.
