does any one know how i can remove the cylinder head cover? i know i have to un screw the 8 bolts butt one of them is underneath the techometer cable witch is in the way to removing the last bolt the bike is a 76 honda cb 360t thanks
Cool that's what I thought my only problem is that my screw is striped any sugestions on getting a striped screw off. Also do you have any spare parts to your cb 360 I need the buckey cup to the front headlight.thanks again
Use a hammer and a small cold chisel to cut a slot into the screw then tap on one side of the slot to turn the screw. It'll come right out then. At least mine did ;-)
