1 - 2 of 2 Posts
Hi guys!
So im stucked and maybe one of you fine gentlemen can give some sugestions.
I am in the middle of a little restoration and want to send my hubs and wheels to get powder coated, but i cant seem to manage to get the sproket away from the hub for the life of me.
I have removed the four bolts, the circlip, the washer, the *bearing retainer (not sure that is the correct name)
Acording to the diferent fiches I have looked at, the sproket should be free now, but I cant make it even flinch...
Any suggestions?
Thank you!
You are fighting rust/corrosion..... Try rocking the sprocket on the bolt ends by alternately tapping it top and bottom/front and rear on its perimeter (at the teeth) with a rubber mallet or dead-blow hammer.... The vibration may break it free, and some penetrant couldn't hurt either.....
1 - 2 of 2 Posts
