I repainted my seat pan on my CB350 and I'm having trouble getting the bumpers and other rubber parts to fit back in nicely. Does anyone have any trick to get them to install back in nice and flat?
Thanks
You can try soaking the part(s) in very warm water and just when your about to install, coat the hole in the seat pan with a liquid dishsoap and water solution then the rubber part and it should slip right in. You could also coax the rubber into the hole with a small blunt screwdriver tip --- but be careful not to use too much force.
Give those rubber bumpers a shot of Armourall and they'll slide right in. If they have hardened they, as the previous poster mentioned, you'll have to soften them up with some warm water or something.
