1 - 2 of 2 Posts
I was checking the air filters last night and after I got the left off, I noticed the regulator just kinda sitting there on top of the tool storage compartment. It appears that it was welded at one time to the top of it. Is that normal and will I have ground issues if not secured to metal?
Stock Honda regulators are rubber mounted (hence insulated from ground except through the green wire...... and, You can't weld aluminum to steel).....
1 - 2 of 2 Posts
