What's the verdict on refacing cb350 valves? I set up my surface grinder and whirlygig and refaced a set of them, they look perfect, but the more I heard about it, if you take more than a few tenths off the face, you've cut through the stellite coating and the valve will prematurely wear out. Then some other people cited articles about stellite being only on the stems, then others said it was stems and faces, then... on it goes. I'm not above buying a new set of valves, but ****, if I've got the tools to regrind them, why not?
