Easy non-meter coil check...You'll need two wires with alligator clips at both ends......
Attach one clip to the Black/white wire on one coil...the other end of that same wire to B+.... Attach alligator clip of second wire to the colored coil wire (yellow or blue).... With a good plug in cap and grounded to head, "spark" the other end of the second wire by touching it and immediately removing it from a good ground (bolt/fin/ B-, whatever).... The plug should spark.... If it does, that coil assembly is good... If it doesen't, change plug cap with the one known to work on other coil, try again....
If it still does not spark, the coil and wire is bad.... If it now does spark, you have/had a bad cap....
If all the above (coils and caps) are good, you have a point problem...Check the wires leading to, and the points themselves....... It could just be a loose connection or a grounded point wire.... Steve
