Just went through very thorough dip cleaning for a pair of VB24s, during assembly found the accelerator pump nozzle to be blocked (tiny spring and ball removed from housing), attempted removal as it had screwdriver slot in it, and shes not moving, may have to be drilled out carefully. But where in the heck can one find a nozzle, as carb kits are hard enough to find for this model as it is (I bought two carb kits, incl. air cut offs, and accel pump diaph/spring). Thanks, Ron
