These switches in most cases need to be completely dis-assembled and cleaned. There's nothing wrong with the design it's just that they are not sealed and exposed to water and dirt on a regular basis. Considering they're all 30-40 years old it's no surprise there's corrosion causing bad contacts and electrical issues.
This is easiest done with the switches removed and on a table, but it can be done on the bike.
This is a good time also to refinish the switch pod housings also if you wish
Right switch pod has more wiring and switches[attachment=34:3906faxs]201_4629.JPG[/attachment:3906faxs][attachment=32:3906faxs]201_4630.JPG[/attachment:3906faxs]starter lead was already broken off[attachment=33:3906faxs]201_4631.JPG[/attachment:3906faxs] but see all the dirt?
It's mostly a case of dis-assembly being careful to watch exactly where each part, ball and spring go, take pictures as you go. The run/kill switch can't be removed from the housing without unsoldering the wires.[attachment=30:3906faxs]201_4601.JPG[/attachment:3906faxs] The switch knob is held on with a circlip that comes off easily and is a real booger to put back in.[attachment=31:3906faxs]201_4600.JPG[/attachment:3906faxs] After you've stripped it down scrub it out with soap and water. This is the dirt and corrosion you'll see. [attachment=29:3906faxs]201_4603.JPG[/attachment:3906faxs][attachment=28:3906faxs]201_4604.JPG[/attachment:3906faxs] Starting with the Run/Kill switch disassemble it completely[attachment=27:3906faxs]201_4622.JPG[/attachment:3906faxs] clean everything, sand the contacts with #600 paper and lubricate it all with di-electric grease[attachment=26:3906faxs]201_4623.JPG[/attachment:3906faxs] As mentioned assembly is a booger since you've cleaned up the spring and ball and they are working now :lol: Assemble it all and upside down pushing against the knob add the washer, position the circlip and pry it into place, took me @10 tries before I got it.
Now on to the headlight switch. There is a brass contact bar that slides across the contact posts[attachment=25:3906faxs]201_4596.JPG[/attachment:3906faxs][attachment=24:3906faxs]201_4597.JPG[/attachment:3906faxs] One has 4 contacts, the other 3. The 4 contact one is for the headlight control and the 3 contact one is for the charging system over-ride on high beam. If you are running the modification for the charging system you can cut the White and White/Yellow wires off the switch and eliminate them from the bar harness completely. [attachment=23:3906faxs]201_4599.JPG[/attachment:3906faxs][attachment=22:3906faxs]201_4610.JPG[/attachment:3906faxs]The contact bar will be corroded as are the contact sliders and need to be sanded perfectly clean and lubed with di-electric grease to insure good connections[attachment=21:3906faxs]201_4618.JPG[/attachment:3906faxs][attachment=20:3906faxs]201_4620.JPG[/attachment:3906faxs] This is a good time to clean the other contacts and add "liquid electrical tape" to the solder connections, assuming you've cleaned the corrosion off of them[attachment=19:3906faxs]201_4624.JPG[/attachment:3906faxs] Now reassemble the sliders onto the contact bar noting which fits where and add the black plastic holder, install the spring and ball and pop back into the housing. Add the brackets and screws and that part is done[attachment=18:3906faxs]201_4625.JPG[/attachment:3906faxs][attachment=17:3906faxs]201_4626.JPG[/attachment:3906faxs][attachment=16:3906faxs]201_4627.JPG[/attachment:3906faxs][attachment=15:3906faxs]201_4628.JPG[/attachment:3906faxs] Now is the time to make sure the switch actually functions correctly both electrically and mechanically. Mechanically you have to push the switch down in the housing to turn the headlight off. This may require you bending the arm or the plate inside to fix.[attachment=14:3906faxs]201_4629.JPG[/attachment:3906faxs] Electrically use a VOM and check resistance from the Black wire to the Brown/White, Blue and White in they're respective switch positions and the Black to Black/White for the Run switch. You should have less than a .5 ohm resistance. More means go back and clean some more.
The starter switch is a grounding switch. I cheated here and used the lower half of another pod since the wire was broken off the original and I didn't feel like soldering it back on.[attachment=13:3906faxs]201_4630.JPG[/attachment:3906faxs] After taking the brackets off the switch just pulls up and out.[attachment=12:3906faxs]201_4631.JPG[/attachment:3906faxs][attachment=1:3906faxs]201_4634.JPG[/attachment:3906faxs][attachment=0:3906faxs]201_4633.JPG[/attachment:3906faxs] Sand, clean, lube and re-assemble. Test for resistance from the Yellow/Red wire to ground when the switch is pushed, should be less then .5 ohm
Now the left switch pod[attachment=11:3906faxs]201_4606.JPG[/attachment:3906faxs][attachment=10:3906faxs]201_4607.JPG[/attachment:3906faxs] Disassemble[attachment=9:3906faxs]201_4608.JPG[/attachment:3906faxs][attachment=8:3906faxs]201_4609.JPG[/attachment:3906faxs] This is the same basic process as the right side of cleaning, sanding contacts, lubing everything with dielectric grease,[attachment=7:3906faxs]201_4635.JPG[/attachment:3906faxs] sealing the solder joints with liquid electrical tape,[attachment=6:3906faxs]201_4636.JPG[/attachment:3906faxs] assembling [attachment=5:3906faxs]201_4637.JPG[/attachment:3906faxs][attachment=4:3906faxs]201_4638.JPG[/attachment:3906faxs][attachment=3:3906faxs]201_4639.JPG[/attachment:3906faxs][attachment=2:3906faxs]201_4640.JPG[/attachment:3906faxs]and testing with a VOM for less than .5 ohms.
