Hi guys - is there any reason that a dome nut would be preferred over a regular nut to fasten the head to the cylinders? Is it for appearance only? I guess it might keep a bit of corrosion off the tips of the studs.
- Any reason for concern if regular hex nuts are used?
No particular reason except that they look better.
Keeps the ends of the studs from corroding. Hex nuts will work fine, though.
