1971 CD 175 with full chain case, cant get rear wheel out unless I remove chain case, should it not come out leaving chain sprocket in place?
Not familiar with your model but just looking at the parts fiche it appears you would need to remove the chain guard.
A factory service manual should answer your questions.
PM sent.
Check owner's manual. My C200, CA95 and CA77 have two axle nuts the small one for the actual axle and the larger for the sprocket/drive hub which can remain in place for say, a tyre change, negating chain readjustment. Still have to undo the brake stuff.
