1 - 11 of 11 Posts
Those are the lock tab plates for the nuts since the nuts don't have a lock washer or self locking device built into them. Very important part. One of the tabs gets bent up against the nut to keep it from backing off.
Reactions: Lost_Cause
There's not enough thread for a lock nut, those need at least 1 full thread exposed above the nut to work. Loctite can be used with the proper nuts but I'd be looking for the lock tab washers.
Me too ... none on ebay as of now it seems
Sent from my SM-G930V using Tapatalk
I've made them before in the past. If you have some thin sheet metal and some cardboard to make a template they are very easy to make at least to get you by until you can get a real one. That said, they should still be available from the dealer.
I search by part number first, if that doesn't work then I'll play with word descriptions.
1 - 11 of 11 Posts
