So I'm having an issue with my CB350 rear wheel. I'm wondering if I forgot something when I rebuilt it, but hoping i didn't, and keeping my fingers crossed that i'm just reinstalling it wrong. however, i cannot find anything i'm doing wrong compared to the manual. Here's my situation:
Complete disassembly and reassembly of rear wheel. ripped old wheel completely down, removed all brake parts, removed bearings and assoiated collars and bushings. Pressed new bearings in, including the notoriously-lost bearing collar and spacer bushing. just reinstalled new shoes and springs. i don't have a rim on yet, waiting for parts from Buchanan's, so i'm working solely with hub and brake. when i install the hub, i'm pushing the axle from brake side, through tensioner bracket and swingarm, bushing, into brake plate, through bearings, bushing on chain side, tensioner bracket & swingarm, and nut and washer outside swingarm. When i torque the nut to roughly 1/2 spec'd torque (~30ft-lb), the hub will not rotate. am i missing something?
Each bearing appears to be flushly mounted, and there's a little bit of slop in spacing bushing (part 7 in pic). the brake-side bushing (part 3) is flush with the brake plate, and the drive-side bushing (part 5) is flush with the bearing's inner sleeve.
any ideas on why i'm binding up?
