Replacing chain, front sprocket and rear sprocket and noticed that the original rear sprocket has a bushing and the new sprocket does not. The IPB (item 2 in the rear wheel diagram) does not show this as a separate unit. Any ideas?
You have to transfer the spacer from the oem sprocket to the aftermarket sprocket if the aftermarket one fits loose (which most do). The spacer isn't sold separately as an oem part, however, DSS has them if you need a new one.
Do a search by part number there and enter PSPACER (all in capitols) there, Ted.
Yes, that's the spacer. It's and extremely tight fit into most sprockets due to the serrations on it. I filed them down so it was a bit easier. OEM was smooth.
Reactions: nebula
Guys, is this a CM400 thing or does a 350 have this spacer? I ask because I just ordered chain and sprockets and would like to have everything on hand. The rear assembly looks different in my 350 parts diagram. I see 70mm washer but no spacer.
Thanks
I don't believe the 350's use one, it's only for the Comstar wheels as far as I know. The CB400T1 with spoke wheels doesn't use one nor does the CB450SC, Nighthawk.
