1 - 2 of 2 Posts
I have a 71 CB350 cafe that has rearsets mounted to the old passenger peg mounts. I’m trying to figure out a way to install passenger pegs and keep the rearsets where they are. I was considering replacing the bolts at the bottom of the shock mounts. Is there any reason this wouldn’t work? Does anyone have any other ideas?
Oh, it will work if you make them strong enough (though to make it strong and reliable enough might prove to be difficult because of the bolt size restriction), but I don't think your passenger would care for their feet going up and down with every bump as the swingarm moves through the distance of the shock travel. the older small Hondas had the passenger pegs attached to the side of the swingarm for a while but it ended somewhere in the mid to late '60s IIRC
1 - 2 of 2 Posts
