I have a CB350G and I can't find seat cover replacements that have the chrome trim along the bottom edge. If I buy a replacement cover it looks like I will have to reuse my trim from the old seat. Is that possible and has anyone done it? Or is the trim impossible/hard to reuse? Problem is I can't really tell how it's affixed to the vinyl without dismantling it, and I don't want to rush in and do that until I know it can be reused.
Pretty sure that trim is similar to the 450's. If you lift up the seat, you should be able to see some posts stuck through the seat cover with semi round clips holding the posts in place.
Got it, thanks. So those posts hold both the vinyl and the trim in place?
Sorry, just got to answering this. No, those posts hold the trim to the outside of the cover. The cover is held on by a bunch of spikes on the inside rim of the seat pan you'll have to bend out and bend back when you replace the cover.
