1 - 2 of 2 Posts
Hi I’ve got a cl350 1970 and a cl360 18 hub and rim has just come up locally
Are they compatible and will there be an issue with rake if the front end is lowered by using a 18 rim
Cheers
J
Wheel will bolt right in, but fender gap will visibly increase..... Slight reduction in rake will theoretically make it steer quicker but be less stable at high speed, but you may not even notice with that slight a change ......You could reduce that effect by going up one tire size in the front....Or one smaller in the rear.....A 3.50 x 18 yields the same axle to ground height as a 3.00 x 19.......
1 - 2 of 2 Posts
