I have a Honda 175 vert that is set up to race. the bike has SL350 24 slide carbs on it. I have the float level set up at 25mm.
The bike still seems to have to much fuel at idle. almost like the fuel in the bowls it to high. I cant get a good idle even at 2k. If I turn the petcock to off the bike is using up the fuel. As the fuel level drops a bit the bike moves up in idle from 1800 to 3000. Do you think that the floats should be set up lower in the bowl? It pulls strong with the lower level in a short test. Not sure how it would run long term this way.
The mains are 100 and the slow are 38
