1 - 12 of 12 Posts
Not strictly a Honda Twin issue, and not even a tank issue really - but ...
I have one of these that I want to bring back to bare metal, with a view to clear-coating it, or lacquering it to preserve the bare metal finish:
It's the airbox cover off my VRod - which sits atop the airbox, and to all intensive purpose looks like the fuel tank. Looks to me like it's made of similar type and gauge material to a conventional metal fuel tank. The key issue for me would be finding a way to do it as easily as possible, but also in such a way that I don't damage the surface, and leave it looking like a (slightly patinated) alloy tank, more like this:
I thought I would ask on here as you guys know infinitely more about practical working methods than most of the bolt-on-accessory merchants who seem to frequent most HD forums.
Any and all inputs gratefully received :)
Thanks,
Alan
Have it dipped at a radiator shop. If you want a DIY method, buy some strong aircraft paint stripper.
I like the sound of that :)
For info - and forgive me if it sounds like a stupid question - do you mean a car/truck radiator repair operation, or somewhere that dips the domestic 'radiators' as we call them here:
I know there is a thriving market for refurbed ones of these round this part of the world.
Eastwoods powder coat stripper would do it but by the time you order it and coat it then let it sit for a couple days it wouldnt be to fast.
Bill
I'm a fan of the spray-can chemical stripper approach (some work better than others though).
Anything you do will oxidize the surface and require some sort of polishing after.
Even a dip tank will leave swirlies and weirdness on the surface.
Aircraft Remover?
^^^"aircraft stripper" +1 ^^^^
Wear eye and hand protection.. the stuff burns..
it's easy to use.. and once brushed on, cover the surface with plastic to keep the stripper "wet" and working..
I worked for HD, those V-Rod tank covers with color are made of plastic. In order to get that look you will have to use a special paint.
I have 3 different covers Franky - none of them are plastic.
I'm struggling to recall any of the models coming with plastic aribox covers - anodised alloy perhaps in the early days, but never heard of anything other than steel or aluminium ones :confused:
They must have switched to plastic in the later years or my memory is shot, you make the call.
Discussion Starter · #12 ·
I think you could well be right on the former Franky. Couldn't find a spec online, but the later restyled 'Muscle' model has a different shape cover. A close look at the pics doesn't confirm it for sure, but I wouldn't be at all surprised from looking at the underside of the cover if it were some kind of hard plastic.
https://www.ebay.ie/itm/Harley-Davi...566748?hash=item212a6adb1c:g:V4gAAOSwfJJZaPj8
Mine are just plain old fashioned steel tho :(
1 - 12 of 12 Posts
