I am sorting through parts that need to be rechromed and would like to have the taillight base done but I am not sure if the reflector and bulb socket are removable from the base (SL350-K2). Has anyone done this and how is it done? thanks - dave WebRep
currentVote
noRating
noWeight
correct, the rest is pressed and crimped in place. it would take a lot of effort to figure out how duplicate that assembly process if you were able to get it apart without damaging the components.
Discussion Starter #4
Thanks for the replies, I was afraid it was not designed to come apart easily, the back side has rust on the outer edges so I guess I will probably clean it up the best I can until I can find a better replacement. WebRep
currentVote
noRating
noWeight
