So I'm knee deep in my ground up rebuild of my 70 CL450. I'm moving onto my engine which I pulled and was going to clean the outside of. Looked into the exhaust ports as I was about to block them off and saw a think carbon build up inside. Before pulling the engine it ran well and has great compression.
Is this something I need to worry about/look into and clean up?
If so what the easiest and most cost effective way? Can I do it or best left to a shop?
If it's no big deal I'd rather not have to stop my build and spend more time and money on it...
Picture attached. Auto part Gear Metal Hardware accessory
Cheers
DW
Well since this is my first build and I'm learning as I go I'm thinking I don't want to screw anything up so maybe I'll leave it alone until down the road when I pull it again for a proper engine overhaul. I'm thinking how would I get the crap out of there that I scraped and what if the valve isn't closed and some of it gets into the cylinder etc...doesn't sound worth the risk for me if it's not a big deal...
Totally normal. If you're concerned about carbon please don't look in your headers. ? If you want to do something good while you've got the pipes off, do as others have advised and replace those copper washers.
I only cleaned mine out when I did a top end rebuild of the engine. Brake cleaner and a wire brush did wonder for that.
