1 - 2 of 2 Posts
on my 71 cb175, one source tells me to remove the stator cover and line up the timing marks, then adjust chain tension, another source does not mention lining up the timing marks, which is correct?
Use the tdc mark, that way there will not be any extra pull on either the front the rear run of the chain.
1 - 2 of 2 Posts
