21 - 40 of 49 Posts
Discussion Starter · #22 ·
Some scoring and pitting in the Cylinders that were too deep for honing so I brought them to a machine shop
Automotive tire Automotive wheel system Gas Rim Composite material
Fluid Automotive tire Gas Circle Composite material
Bored 0.5mm over
Bone Automotive design Headgear Automotive exterior Skull
Automotive tire Synthetic rubber Audio equipment Automotive exterior Automotive wheel system
Some new pistons to match
Liquid Blue Fluid Cosmetics Plastic bottle
Also got my parts back from powder coat, minus the frame. They look amazing in satin black
Wood Font Art Hand tool Metal
Automotive exterior Carbon Bumper Hood Bicycle part
Blue Rectangle Automotive exterior Bumper Hood
Discussion Starter · #23 ·
Got the tank back and it's all clean inside. Glad I can still use the original tank
Door Audio equipment Wood Fixture Gas
Cleaned the side covers and tank again. Not a ton of paint left but keeping it original for now. Debating on leaving the dents for some character or trying to pop some out
Wood Automotive lighting Peach Fashion accessory Carmine
Hood Sports equipment Personal protective equipment Automotive lighting Helmet
Helmet Sports equipment Sports gear Automotive lighting Orange
Discussion Starter · #24 ·
Back to engine reassembly.
Setting the ring gap
Wood Crankset Automotive tire Hand tool Metalworking hand tool
Installed the rings on the new pistons
Tableware Drinkware Mason jar Camera lens Drink
Installed with new wrist pins and new bottom gasket
Drinkware Serveware Wood Automotive tire Auto part
New seals and oiled the cylinders for install
Helmet Automotive tire Automotive exterior Sports gear Personal protective equipment
Cylinders on
Automotive tire Motor vehicle Automotive lighting Automotive design Vehicle
Starting on the head
Hood Automotive tire Motor vehicle Bumper Automotive exterior
Lapping the valves
Bicycle part Wood Crankset Rim Gas
Valves installed
Tire Wheel White Automotive tire Motor vehicle
New guide seals
Automotive tire Rim Bicycle part Engineering Auto part
Discussion Starter · #31 ·
Hello, that's some mighty clean workmanship, A+, what method was used on bottom crankcase, very nice. can you tell us what brand pistons, and what is the black coating?
Cam bearings, covers look great, good photos, gotta love it. Keep us updated. HondaJohn
Cleaning method? It was vapor blasted.
New pistons are Pulsar from Common Motor Collective.
The black coating is satin black powder coat.
Looks like a great project and workmanship! I believe that the Pulsar Pistons are a new item for Common Motor. Their video on YouTube suggests they are high quality. I've not been able to locate availability of those pistons at any other vendor. I would appreciate your view on the quality once you've had time to test drive the bike. Thanks.
Discussion Starter · #35 ·
Thank you.
Yes they are, Brenden hooked me up with them before they went live on their site. Have ordered a lot of parts from them, and am using their videos and advice extensively to do this work.
Discussion Starter · #37 ·
I would say I'm taking a middle of the road approach. No hand sanding. After they were vapor blasted, I started with a soft 240 grit wheel on the bench grinder. Then work my way through black, brown, green, white, blue compounds on some cheap buffing wheels.
74 CL360, 81 CM200T, 85 & 86 CMX250. Invisible to cages, treat accordingly. Avoids Road Rage!
WOW! That's going to be such a sweet looking (& running), bike!
You're doing some beautiful work.
21 - 40 of 49 Posts
