1 - 20 of 48 Posts
Growing up, my Uncle, who lived nextdoor to me, had a 74 Honda CB450 stored in his basement. Me, and all the kids in the area, thought it was so cool and would love to climb on it and pretend to ride.
I've always wanted a motorcycle and knew that when I got one, I wanted one just like his. Last fall I found a bike in New York state and loaded up my VW to leave Ontario, Canada to get it.
Wheel Tire Vehicle Car Motor vehicle
650 kms later I had the bike.
Tire Wheel Plant Vehicle Automotive tire
Quickly turned around to head to the border to get it imported into Canada.
Tire Wheel Land vehicle Vehicle Automotive parking light
Made it back home without incident.
Gave the bike a quick rinse, and off for the first ride and some pics.
Tire Fuel tank Wheel Automotive lighting Automotive tire
Fuel tank Tire Wheel Automotive fuel system Automotive tire
Tire Wheel Sky Fuel tank Automotive fuel system
Motor vehicle Grille Automotive lighting Hood Automotive tire
I have never owned or even ridden a motorcycle before this but I was instantly hooked.
Im not one to leave well enough alone and before the riding season was even over I was digging into the bike - named Project Eagle in memory of my late uncle.
Unfortunately his bike has gotten pretty rough since his passing.
Tire Wheel Fuel tank Automotive fuel system Vehicle
Hi cp,
Lovely pictures all taken by phone ?
May I ask how many miles has the bike done ? Lots of "grey" inside, leaded petrol ?
Also may I ask the piston with the "shineyer" crown ring, which cylinder was that piston from please and hows that big end ?
Lovely vW and workspace...
Hi cp,
Yes these are all with my old Pixel 4a. Nothing special and just a few adjustments in the native photo editor.
16,000 miles showing on the odometer.
Sorry I'm not understanding the last question.
Discussion Starter · #13 ·
Tank has some coating inside that is delaminated from the sides. Sending it to a radiator shop to hopefully renew the inside.
Automotive tire Wood Gas Automotive wheel system Auto part
Taking apart more components for inspection and rebuild.
Wood Audio equipment Gas Electronic device Metal
Gas Wood Electrical wiring Wire Fashion accessory
Air gun Revolver Gun barrel Shotgun Machine gun
Auto part Metal Household hardware Fashion accessory Button
Circuit component Automotive tire Wood Gas Cylinder
Taking apart the seat.
Automotive parking light Grille Automotive lighting Hood Automotive tire
Food Ingredient Sandwich Staple food Cuisine
Seat pan was rusty so I wire wheeled it and put a few coats of Tremclad.
Motor vehicle Bumper Automotive exterior Gas Auto part
Bumper Motor vehicle Rim Gas Automotive exterior
Hood Automotive lighting Automotive design Vehicle Automotive exterior
Foam is in great shape but replacing the cover due to a rip in the original.
Gas Flooring Audio equipment Wood Automotive exterior
Sandblasted a bunch of parts to get powder coated.
Bumper Automotive exterior Motor vehicle Wood Gas
Motor vehicle Wood Font Gas Bicycle part
Used some syringes from Amazon and Testors model paint to refresh the emblems. The raised chrome parts aren't in great shape so they aren't perfect but I'm happy with them.
Motor vehicle Badge Font Automotive design Jewellery
Automotive design Rectangle Font Art T-shirt
Motor vehicle Automotive lighting Automotive design Automotive tire Bumper
Discussion Starter · #18 ·
Starter disassembled. Was working just dirty and just hard gunk and dust where grease should be.
Rebuild kit
Wood Font Audio equipment Jewellery Circle
Bearing and seal out
Automotive tire Wood Gas Rim Nut
New in
Wood Automotive tire Gas Rim Auto part
This should be smoother than before
Wood Tableware Recipe Ingredient Dishware
New parts and cleaning
Wheel Tire Automotive tire Wood Coil
Wood Automotive tire Circle Font Automotive wheel system
Back together (wrong o-ring at this point, noticed when I tried installing)
Gas Cylinder Wood Auto part Nickel
74 CL360, 81 CM200T, 85 & 86 CMX250. Invisible to cages, treat accordingly. Avoids Road Rage!
I may be stating the obvious...but, make sure to use pre-lube/assembly lube, on all of the main & rod bearings. You'll be glad that you did.
I'm only saying this because I can't tell from the pictures whether or not you've already done it.
Discussion Starter · #20 ·
Yes good advice. I'm using assembly lube and oil, basically copying the common motorsport collectives engine rebuild exactly.
1 - 20 of 48 Posts
