Hey everyone!
i have a 72 CL175. It had a blown head gasket so we (a buddy and I) decided to replace it. After fixing that and not knowing how to set the time properly, we assumed incorrectly and set the time 180 degrees off. Would this have lead to bent valves? I know the valves hit the pistons (you can see where the metal shines through carbon build up) but there is no pitting or destruction on the piston.
Once the time was corrected it seems that the valves may have still been hitting the pistons (a grinding sound, but an engine tear down assures nothing is in the case); which is where I draw the assumption the valves may be bent.
The valves are currently at a machinist awaiting reseating and and a valve job. (I have unbent valves I pulled out of a head from the junkyard). I guess I am just looking for reassurance that I diagnosed it properly. I don't know what else could be making this this noise when I crank it.
Thanks.
Thanks.
