1 - 10 of 10 Posts
Chrome plating has become such an EPA nightmare that there are few chrome shops around anymore, and even fewer that actually do good work (see LDR's recent thread - http://www.hondatwins.net/forums/5-vendor-links/107705-jb-s-chrome-shop-portland-oregon.html). I know it wouldn't look as original, but ceramic coating by a powdercoat shop is excellent for exhaust (when done properly) and holds up like chrome. If you've never seen it before, you can look at how mine turned out
http://www.hondatwins.net/forums/1-project-logs/65305-cl450-project-reboot-street-legal-time-2.html#post578305
I doubt a chrome shop will do the old pipes as the carbon build up inside the pipes and mufflers contaminates their chemical tanks.
I would second the ceramic coating idea.
I wrote it in the thread that ancient refered to, but Metro Plating in AZ.
I have the pipes and mufflers clean inside. I started with 2+2 gum cutter and then soaked them internally with a solvent called surface prep or final wash which is used to wipe down items prior to painting. It is like a wax and grease remover. I will call metro Plating, I have one other possibility that said if I got the pipes clean they might try and re chrome them.
It can be done.
The plater needs to block off the internals. I have heard of them using expandable rubber Plugs on both ends to seal the pipes and prevent them from contaminating their chemicals.
I talked with one plater who was going to plug the pipes but when I sent him pictures said he could not plug the muffler end because it is a double pipe at the end.
I will keep trying.
Mufflers will be a problem.
The CL Mufflers also have a small VENT Hole which they would be challenged to block off.
I'm not sure why everyone has had so much trouble with exhaust/mufflers -- I'm not a chromer, but I have taken quite a few sets of exhaust along with other stuff to three different chromers in Arizona and I have never had any of them raise an issue over used exhaust.
1 - 10 of 10 Posts
