Hi, I'm a new member here, but have been reading and learning a lot on the forum since I bought a '73 cb350g a few weeks ago, so thanks to all.
I cleaned my carbs up the other night and when I reinstalled and turned the gas on, gas came out of the bottom of the float bowl.. I figured the float was stuck so I took it apart again and made sure it was all good.. turns out there's a pin hole in the bottom of the float bowl.
Anyone run into this and figure out a good fix? Would something like JB Weld work?
Thanks for any thoughts and insight.
You can see the little black dot between the stem and drain plug- that's the culprit.
