The OM is rather vague regarding this... all it says regarding the monthly maintenance is "check the major fasteners and tighten as needed". What would the major fasteners be? Wheels and steering?
Totally unrelated question: total tank capacity is 16 liters / 4.23 gallons. I'm just curious: is that the capacity when you fill the tank up to the filler neck?
Personally, i just go over all the fasteners. Every bolt on there has a job to do and needs to be secure. 16 liters is the designed fuel tank capacity, it's very unlikely that the finished production part actually holds exactly that amount.
Every single month though? I don't know, that seems a bit overkill... :p
Check em once and you will get to know which ones are troublesome and which will be fine. It doesn't take long to do a quick inspection.
