I have four 1969 CB250/350K0/K1's I am restoring and recently bought some NOS parts for them.
Take a look at the pics ..On the points plates ..The LH one was boxed and is the standard part but the one on the right has much shorter cables.I suspect it's a CYB 350 part as I also got some CYB350 valves from the same source. Also I have a 286 cam follower but the valve contact end looks beefier than the standard one next to it got any ideas.
Comfort food
Metal Auto part Tap Bicycle part Rim
Do the rockers have the same lift?
Place flat on table, side by side
Thanks.. I just did as you suggested and with the valve ends sitting on the table, a significantly bigger gap between pad and table surface, at the cam end, with the one on the LHS than the NOS one on the RHS (the used one is not really worn)
Ash; you need this book..
Text Red Pink Font Magenta
Pm me your address and you can borrow it to copy for anoraks corner..
Regards
Nigel.
What are the part numbers you want to know and I’ll look them up for you Ash. I’ll post the book tomorrow.
Nigel.
Nigel.
Thanks ..... I am OK for the part numbers and I do have a parts list for the CYB350 but some parts are not in original marked packaging.
I guess the short lead points plate may be 30200-286-970.
Scanning your book will be most useful though.
