1 - 1 of 1 Posts
I just signed up here and went to post a want ad, but discovered I needed to contribute to the forum first. I'm not sure what I could possibly offer that you guys don't already know, but I'll show you something I just discovered.
So in the process of restoring my newly acquired '78 CB400 to nice running condition, I wanted to replace most of the screws in the carbs and related assembly, since they've been mutilated by previous owners. I noticed that most of the screws have captive lock washers, but when searching parts diagrams I noticed the screws and lock washers had different part numbers. For example:
5x12 Pan Screw
93500-05012-0H
5mm Spring Washer
94111-05800
4 of each of those would be needed for the upper brace on the filter side of the carbs.
OK, so then I happened to discover that if I looked at a diagram for a '78 Hondamatic, there is only 1 part number for the screw and it's called a "Screw Washer". For example:
5x12 Screw Washer
93892-05012-08
I much prefer the captive type, and was happy to discover this.
Did you guys already know that? :unsure:
1 - 1 of 1 Posts
