1973 CL350 lower case with a stripped oil drain hole. Pieces of thread are cracked off/missing. When you think of the tens of thousands of these classic engines produced, I was hoping there was a kit of some sort to deal with it. Somebody must have stripped them the last 50 years! If not, weld up area and cut new threads? Weld in a bungs? Consider the case unusable? I sure don't have a tap that big.
I'd admit it if I did this, but I've been doing Honda oil changes since my 1971 CL70 and "inherited" this problem! I appreciate any helpful and experienced advice from you all.
Drill and tap the center of the old drain plug for a 1/4 inch pipe plug, then JB weld the plug into the crankcase.
Reactions: Bill H
Good idea, Mike. Hard to believe... in all my time involved with these things, I've never seen one with damaged threads. Plenty of rounded off hex heads making a pipe wrench a requirement to remove it, but not this
Time Serts only go up to M24 X 1.5 size- 350 drain hole is 32mm. Too bad- that would have been the best solution.
