Hey guys, I've had a small oil leak out of the front right corner of the clutch side cover. It was pretty consistent (about one drip every minute, and dripped more when engine was running), so I opened up the cover this morning to see if the gasket was torn or if there was a nick in the case that could have caused the leak. Here are some pictures of the area in question with and without the gasket. Is the oil filter screen rubber supposed to overhang the crankcase this much?
More info: the leak started after I changed the clutch plates a couple weeks ago. I replaced the gasket with one from dime city cycles and closed it up. I did not use sealant or grease when I installed the gasket if that might have been a potential problem. The gasket had oil all over it when I removed it from the cover. In addition, some of the bolts may have been installed incorrectly as a couple of them would not tighten down no matter how much they were turned. But the bolts in the area of the leak could be completely tightened so I didn't think that was the issue.
I purchased another gasket from David silver spares, some gasket sealant, and a new set of bolts for the cover. Will this probably fix the leak? Any words of advice?
Thanks guys!
Thanks guys!
