Pretty sure the points housing gasket. I replaced the gasket and it seemed to stop. It's the one gasket I forgot to replace when rebuilding. Stupid.
Discussion Starter #4
A few of the head bolts had a little more threads to go. Hoping my problems are gone!
You made sure to install the tach housing gasket forward and not backwards, right?
Replacing the points housing gasket with the bike in frame is super tricky.
It's only because it's difficult to get enough cam chain slack to allow the cam bearing cap to go on the cam without force on the 350, and if you force it on it can cause damage to the aluminum bearing surface inside. You'll probably be okay as long as it wasn't too forceful an effort to get it back on
