I purchased a very neglected 1975 cl360 and i am in the process of disassembly. I wanted to drain the oil while engine is still in the frame. I put a socket on the oil drain bolt and it rounded. I plan to take the engine out and will just try to take the clutch cover and generator covers off to dump the oil out. Then i should be able to lay the engine on its side to get some better access to the oil drain bolt. Any problem with my plan? Also, is an ez out a good way to try and get the bolt out?
Thanks, Gary
Thanks, Gary
