Got the old 1970 CB450 running. I stuck the shifter lever on the shaft coming out of the engine case. Ran through the gears fine. Went to down shift and wouldn't go. I applied a little pressure and it felt like it was grinding a gear. Not good. Then I noticed how much play there was in the shaft and found the old worn out rusted snap ring was just riding up on the shaft. See Pic.
How bad is it. Do I have to split the case to get it to line back up?
