mtnlvr said:You say "replaced the clutch". Does that mean you had the clutch basket and all of the disks replaced? What exactly came off the bike and what was replaced?
Did it shift fine before the replacement?
May sound dumb, but are you sure you're getting your foot out from under the shifter every time you shift? Not letting the shifter return to its neutral position will keep it from shifting to the next gear.
That spring should be clearly visible when you take the right side cover off. You'll see it just below the clutch basket.dpb said:Yeah, I opened the case, and I wasn't able to see that spring. I think accessing it would take some digging. I adjusted the lever yesterday because it seemed like it was coming really close with the case, but I'll see if bringing it out on the shaft a bit solves it. Thanks for the help, much appreciated.
Hello HerrDeacon,HerrDeacon said:That spring should be clearly visible when you take the right side cover off. You'll see it just below the clutch basket.dpb said:Yeah, I opened the case, and I wasn't able to see that spring. I think accessing it would take some digging. I adjusted the lever yesterday because it seemed like it was coming really close with the case, but I'll see if bringing it out on the shaft a bit solves it. Thanks for the help, much appreciated.
