21 - 34 of 34 Posts
Discussion Starter · #21 ·
nigelrharris03 said:
Just to identify the indicator panel its from the 400/4 and the 650Z/4 at least ;) possibly other 4's too.
i think i might keep that one peice, looks too good on my bike, with the nice shiny jeweled indicators instead of the dim flat ones on my nighthawk
hole pattern seems to match up too....
I looked at that, 400f doesn't have 'Stop Lamp' legend on so wondered about the wiring.
Discussion Starter · #23 ·
its just a box of lights, theres always a way!
The 650Z I have doesn't have a brake light feed to the indicator panel either.
There is only one bulb there which is for the oil pressure.
I guess you could fit an LED in if you wanted it to to act as a front and rear brake light mimic too.
malcolmgb said:
steveo said:
37250-377-008 speedo, unknown application
also matches numbers 37230-369-671, 37230-369-740 , 37200-387-771 , 37200-388-601 , 37200-388-602
This has 75-76 CB400F written on the box, that might be the correct application
[attachment=0:2f81bkmv]37250-377-008.jpg[/attachment:2f81bkmv]
Can you pm me how much for this one please.
Were you able to get a price of this for me? The part number is for a tacho.
Hi. I'm interested in the speedo and tach you have on listed on your first page. The ones you have listed as part numbers 37230-369-671 and 37250-377-008.
Please let me know how much you'd like for both shipped to Cincinnati, Oh 45236.
I tried to PM you, but it doesn't look like it sent.
I see that this is an old post, but if you still have some tach/speedo assemblies around, I'm interested. The part numbers for my bike (1971 CB450K4) are as follows:
37240-346-008 (tach)
37230-319-671 (speedo)
If you have these or something else compatible, let me know!
Thanks,
Josh
steveo said:
37600-426-772 indicator panel !
unknown application
[attachment=0:3u0u8mnp]37600-426-772.jpg[/attachment:3u0u8mnp]
I'm thinking this is from a gl1000, as that is the only one that I would expect to have a brake light warning. Other models used a very similar panel such as the aforementioned cb400f, plus 76-78 cb550f, 77-78cb750k, 76-78 cb750f.
The -426- center triplet says it is/was originally for/from a 1979 CB650........
37250-MC9-670 (subs up to 37250-MC9-861 as written on the box, but this is the original numbered gauge) tachometer
fits CB450SC 1982+
[attachment=0:3621bz2w]37250-MC9-861.jpg[/attachment:3621bz2w]
This is probably a long shot, but do you still have one of these laying around?
Hi there
interested in the idiot light/signal assembly. In Penticton BC. Please send a price for this item. Also looking for carb insulator(s) 16211- MC1-000. Thanks... Thorinn
Hi there
You're likely wasting your time responding to all these posts that are over a year or two old. You should check the OP's profile first to see when he was last on the forum.
21 - 34 of 34 Posts
