Just a quick post. Trying to get some insight. Took off the valve covers on the 450. Inspecting Cams and Tappets. Does the lobe wear seem normal for a old 450? Also noticed the edges of the lobes are razor sharp. Is that normal?
Automotive tire Motor vehicle Rim Wood Gas
Tire Wheel Automotive tire Motor vehicle Rim
Wood Motor vehicle Bumper Automotive exterior Gas
Motor vehicle Gas Wood Auto part Musical instrument
Not exactly perfect, but better than some we've seen. I would be inclined to run them as is, at least for a while. I like to add an extra .001" to the valve clearance settings, to leave room for a little thicker oil film between the parts.
Reactions: Irokori
I agree run it, as long as you can still adjust the valves. Excessive wear on rockers would prevent that.
Do let the bike warm up 4-5 minutes before riding, “required on the 450, and make sure your fuel shut off is working, fuel in gas and no warm up kills these engines. I shut my fuel off and let it run till it starts to die before I turn the key off, I also have clear fuel lines so I can see that the petcock is working.
And avoid using sealer...I wonder how much is covering the oil pick up pipe filter, and lurking in threaded holes waiting to burst a casting.
Don't use it.
New gaskets, or learn how to make your own.
I was able to set clearance .004"
I used the go - no go method.
.005" no go
.004" go
On to setting points/ignition timing. Wish me luck!
Mr Honda says 1.5 thou many of us set at 2 thou because it is easier to us a 2 thou feeler. 4 thou is more than twice the recommended gap and will be loud.
Why not follow the Honda specs?
I followed...
I've seen were .003" is recommended these days.
