Haie Guys ,
I have a question ; I have a CJ360T from 76 which didn't have a side stand. I bought a side stand and to my surprise there is no way
of attaching it. I have the suspicion that previous owners have tampered with the frame.
Can somebody confirm this (I am more of a engine guy) ? Would it be possible to adapt the frame for a side stand or is that to much of a hassle ?
R.
I would say someone cut the mount off, it should be right there under the foot peg. If you can find one and get it welded back on it should be fine. There are also clamp on versions around if you look for them.
I always thought that the CJ was sidestand only and did not have a main center stand, which was one of the mostly cosmetic differences between a CB (which was my first bike) and the CJ. Tank, tailpiece, 2-into-1 exhaust, side covers, drum front brake?
But it’s been a long time
I think European models were a little different (or I have a CJ360 engine in a CB360 frame). I have a front disc brake and rear drum. I do have the 2-into-1 exhaust.
R.
If its a CB frame it will say on the headstock. As far as I have seen it on this forum, CJs have always had a drum front if they are in the US, however a little googling in the images section comes up with this
Its in the UK and has a side stand. Does have a disk front.
As far as clamp on sidestands, google again can be your friend. As you are not in the US were I would guess most of the sellers for such items are it may be best to do some searching. I get about 600k results when I google "clamp on motorcycle kickstand".
Yes , this looks very much like the bike I have (and I can see where the side stand is supposed to be).
I indeed googled for a clamp on side stand (should have done that in the first place) and found several vendors in the UK.
Belgium isn't exactly petrol-head country :(
R.
